Hi
Does anyone know why I get a blank notepad when I start PBX?
I also get one for every different table I start.
These are visible on my desktop once I close PBX and I then have to close all the notepad boxes on by one.
Any help would be appreciated.....thanks.
You probably have the default launch scripts enabled.
Logfile and settings file are appreciated as well when creating an issue😁
Btw. Did you ever solved your issue that loading a table takes 2 mInutes?
1 hour ago, pudie said:
Hi
In settings.exe make sure you have the launch before and after set to no for whatever systems you're using where the executable is Notepad.exe;
