HELLO,
How do I get the wheel with all the VPX and FUTURE tables in pinballx home.
Currently I have the proposal of the 2 emulators VPX and FUTURE PINBALL.
If I modify the parameters by asking to no longer display the emulators, I only have the VPX wheels proposed
and not that of FUTURE PINBALL!
How to do have THE WHEEL OF FUTURE PINBALL too ?
THANKS
duv
Please post your log and ini file
I don't understand what you mean with
If you set the systems to disabled, you won't see them in the front end.
There's also an user manual available when you install pinballx. Did you check that? It describes most of the features of pinballx
@duv67 Please attach your pinballx.ini and log.txt files when asking for support. It sounds like you have 'one click launch' enabled in settings but hard to say without those files.
