Hello,
When I launch the HALLOWEEN PINEVENT V2 table in PINBALLX, towards the end of the loading I hear PINBALLX closing, the table ends its loading but another table is launched by PINBALLX, starts loading and comes to cover HALLOWEEN! This also happens with F14 TOMCAT but not with the SONIC table!
Any idea of the problem?
attached my parameters futurpinball and pinballx buttons
THANKS
DUV67
Can you also attach your pinballx\log\log.txt and pinballx\config\pinballx.ini files
Make sure the log file is from after seeing the issue. Thanks.
Thanks, please note that you can just attach the files, it's easier for us to read and there's no need for you to take all the screenshots
From what i can see though the Future Pinball launch parameters look suspect. Can you change them to;
Parameters=/open "[TABLEPATH]\[TABLEFILE]" /play /exit /arcaderender /STAYINRAM
If that doesn't work please attach (as files!!) fresh copies of your pinballx log.txt & pinballx.ini files.
+1 to what he said. Always attach copies of your pinballx.ini and log.txt files as attachments when reporting an issue - so much easier to read!
  • Draco1962 changed the title to [RESOLVED] tables PINEVENT V2
  • Draco1962 locked this topic
