Hello all,
I turned on the cabinet today and for some reason the marquee isn't working anymore. I'm providing the rquired ini and log files. I've tried completely uninstalling and reinstalling everything to no avail. any help would be appreciated
GameEx.ini log.txt
Assuming you are referring to the Pixelcade marquee you noted from a prior post.
Have there been any recent changes/updates to your Windows installation? I pulled a log file from a recent post that shows an "Unknown Windows Version" and the latest log file now shows "Windows 11Microsoft Windows 11 Home 64-bit."
If you recently upgraded your Windows to 11, have you reached out to Arzoo to confirm that the LEDBlinky plugin is compatible? Same question for Pixelcade.
Im at a loss as to why different things are showing up. Ive been running windows 11. i was running 11 when it was all working, this is weird.
FWIW, I tested with my PC with Windows 10 Pro x64 with v18.36 of GameEx and GameEx Arcade Edition and Pixelcade marquee launches and displays without an error.
I wouldn't give up. I had an issue with GameEx displaying a "black screen" after updating to the latest version.  It resolved after I re-downloaded 18.36 and performed an over-the-top installation. Not the same issue but maybe worth a try?
Check the file names and formats of those that do not work.
Do you get any of your files from the Pixelcade sources?
Yep got em from Pixelcade install. So far everything works except for Tekno Parrot and Switch. What's weird is Panasonic 3DO didn't work and now it does.
On 1/31/2023 at 8:34 PM, Draco1962 said:
You may want to check this out, especially when it comes to adding new systems:
Customizing - Changing the default marquee image or animation
Besides covering how to change default marquees, it also instructs on how to add new systems.
Mike
This link did the trick, Thanx Draco!! I'm now in the process of changing things to suit me. I did get Switch and Tekno Parrot working again.
  • Thanks 1
  • Draco1962 changed the title to [RESOLVED] Marquee Help
