Wheel images stop displaying, and now exit/freezing issue
Hi there thanks for any help resolving my issue - - initially I was trying to solve an issue where all wheel images 'disappear', usually after playing a game and returning to front end. I can make the images show by closing / restarting Pbx.  I updated to the newest version and the issue continues, and also I have a new issue where I cant seem to successfully close out of some tables, (usually vpx 10.7 tables.) - both my exit button on my cab, and the exit keystroke on my keyboard fail to leave the game, usually I need to force close out of all programs and restart the program
log and ini files attached, thanks again for any help getting my frontend working again!
Mitch D
log.txtFetching info... PinballX.iniFetching info... SetupWizard.logFetching info... XDMDlog.txtFetching info...
@dielated the windows feature to turn off if you don't have a low disk space issue is 'storage sense'. That should resolve the wheel issue.
For the exit game issue can you post a screenshot of your visual pinball key / button config screen and let us know what button (number) you use to exit a game. Also, is it only some games that you can't exit out of, but some exit ok?
About the3xit button: Whats the different between your "visual Pinball" and the "VISUAL PINBALL 10.7" system ?
Visual pinball system has no full screen exclusive hack, but according to your log ( that is using the 10.7 exe) it is using the FSE hack.
And whats the different of the 2 exe files ? As visual pinball 10.7. Is shipped as visual pinball.exe as well.
So, what did you do in that directory ? As both directories are c:\visual pinball
Thank you guys - here are screenshots of my Pbx and my pinscape buttons. The couple times this happened yesterday both my cab buttons and the 'Q' or "esc" keyboard keys also didnt respond
I have turned off storage sense - will report back if it happens again but hopefully that will do it!
Mitch
Hey Mike - I have 10.7 'sideloaded' along with Visual Pinball - I added a folder at c:\visual pinball\10.7scripts    , and renamed the .exe file and put it in the main c:/visual pinball  directory, and then added as a seperate system in PinballX so I didnt have to change all games at once.
I believe I have 'full screen exclusive' checked as an option in both versions of the program that I run,  I havent done any 'hacks' or anything.
Also to @scutters it is not happening to all tables and I havent been able to make it happen again yet today, I will report back if I can narrow down which tables specifically arent closing out well. One of the repeat offenders is the GOTG tribute table with pup-pack.
So just a quick follow up - the exit button will reliably not work to close out of the Guardians of the Galaxy table -  I also tried to exit out of VP emulator by force, and it caused Pinball X to freeze, wouldnt let me take back control without restarting.
I am trying other 10.7 tables with pup packs to see if I can duplicate the issue...
Not that this will fix your exit button fix, but why did you mapp your Pinscape to keyboard mappings ?
Why not using the Joystick buttons ?
I switched last year to the pinscape controller when my Virtupin controller didn't work anymore.
These are my settings :
image.thumb.png.184cf387a024375751ca49bf80b4a2de.pngimage.thumb.png.249a77e82d48de5d831ea0caf3f6834b.png
(I only map 1 button toy to the "End" key, as that's my coin door. Unpressed is closed, constantly pressed is open)
Check your visual pinball settings, if the "Overide default button layout"and "Disable ESC key" are checked as well
