I have loading folders running on a veryicsl screen vpx tables show vertical with  the loading gif but when I open verticsl mame it shows horizontal images  as though the cab was portrait, so they are the wrong way round gof the verticsl screen. I only have verticsl games set up in Mame.
Any ideas please
Might need to take a look at some of your sample images. Can you attach a few please?
  • 1 month later...
Hi When I start the game I have vertical image I press play and then i get the loading image sideways on.
Where are these images kept as I've been through all my folders.
Screenshot_20230208_193151_Gallery.thumb.jpg.3cefc6716145b0196d267a1e3150f0fb.jpgScreenshot_20230208_193121_Gallery.thumb.jpg.e5f83da88e8d88b8fe4bb9661e21f0aa.jpg I have no issue in pinballx only in Mame it occurs
Please attach copies of your pinballx.ini, log.txt, and mame.xml files for review.
Please advise whether or not it is thr loading image that is being rotated or the actual game play.
My assumption is that you rotate you screen after the game is launched ( but as @Draco1962mentioned, please attache your files, so we can confirm)
Shipped with PinballX , there is a manual as well. Chapter 5.2.3. explains the system folder directory
