[RESOLVED] No sound when I return the frontend
Long time user with no issues.  All of a sudden, when I go into a table and exit, eventually I lose complete sound in PinballX.  When I go back into a table the sound is there fine.  PinballX also starts out okay with sound.  Sometimes I'll lose sound even when merely browsing through the tables after going into a table initially.  I've never had an issue like this before.  I've tried reinstalling PinballX, disabling AIO Equalizer and Pinvol, but to no avail.
Also, after losing sound, I can go into a new table and sound is fine.  When I return to PinballX there's no sound.
Further update, exited out of PinballX, went back in, heard initial sound when switching tables, then  no sound.
I don't have a clue.
Was this issue introduced during an upgrade of PinballX version ?
If so, it can help Tom to identify the cause.
Maybe try to revert a couple of version back and try to reproduce the issue.
Not sure if you set your windows to autoupdate , but could be that an update causes this issue (but thats a long shot)
Logfile looks fine.
What you can try ( but just for testing).
Rename the bass.dll from your pinballX directory to bass.DLL_org .
Go to https://www.un4seen.com/ and download the Win32 version :
Within the zipfile copy the bass.dll from the X64 directory, to your pinballX directory
start PinballX and check
Not a solution, but  just try to help you
Logfile looks fine.
There was a Windows update that precipitated this issue, but, as a result and before I pinpointed it to the Windows update, I also updated and reinstalled PinballX, EqualizerAPO and PinVol.  So yeah, there's that.   I appreciate the suggestion.  Perhaps I'll try to revert to the version of Windows prior to the update.
Even more weirdness that makes me wonder if it's a PinballX issue after all?  Loading a table and while playing, there was a definitive pause and next thing I know, the flipper channel goes out.  When I returned to PinballX the change table sound no longer works.  I did replace the bass.dll file like you suggested, but this now sounds more like a windows issue with the USB sound card no?
If all was well before you updated Windows, then very possible there is a driver compatibility issue introduced and not a PinballX issue.
If you have niche devices or software, such as Pinscape or Pinvol, then a question would be have you checked the sites for any issues reported post update and any patches from their devs?
Fingers crossed, but so far either the bass.dll trick or reverting Windows update has fixed the issue.    I did check the third party sites for updates, but nothing yet.
As an update, it happened again, but unusually particular to the Tales of the Arabian Nights table.  While playing, it would pause for a beat and then I'd completely lose the sound of the flippers only.  Thinking at this point it must be a driver issue.  I completely uninstalled Vpinmame, PpinballX and my Startech USB sound device software.  I then reinstalled pinballx and vpinmame and copied over my original files from before.  I elected not to install any specific software for the Startech device relying on the setup provided from Windows alone (which does support a 7.1 setup anyway).  I'm hoping it was the installation of the Startech software that maybe caused it not to work because TOAN is now working fine.
Ah. The startech 7.1 externall usb audio device. I had that device as well, and causes issues as well. It solved when I swapped my main board with on board Realtek soundcard 7.1
  • Draco1962 changed the title to [RESOLVED] No sound when I return the frontend
