Hi I have downloaded the above table loads fine in VPX, but will not load on Pinballx  I'm running version 5.5  any ideas please all my other tables load fine.
Can you try and launch it from PinballX then attach your pinballx log and ini files and let us know what happens when the load fails (an error in VPX or something else?)
Have tried again I just get a black screen, after I shut Pinballx down vpx loads it. All my other tables load fine.
When I open it to take a video of the table it loads straight up.
log.txt PinballX.ini
Do you run VP in 'full screen exclusive mode' ?
If so, enable it in your settings.exe for vp as well
If not, enable it within VP and turn it on in settings.exe as well.
You can always revert this setting
Tried it nothing still black screen, Pinballx freezes I shut down with task manager  then Poltergeists comes on and Pinballx menu then starts really strange.
Also, what happens if you open a cmd window and run this command, does VPX open the table, hang, or error?
copy and paste the exact text;
F:\Visual Pinball\VPinballX.exe /play -"F:\Visual Pinball\Tables\Poltergeist VP Cooks.vpx"
Just loaded snother 2 tables into Pinballx and redownloaded Poltergeist  and it booted straight up with no issues.
Thanks for the help
  • Draco1962 changed the title to [RESOLVED] Poltergeist vpx
