tthurman Posted October 14, 2022 Share Posted October 14, 2022 Quote Arcooda 20″, 4:3 flat-panel monitor that was designed as an arcade monitor replacement. It accepts resolutions from 240p to 1600×1200, has 2ms of lag and scaling can be set to sharp for retro games. I've been waiting for these to become available, looks like a modern replacement for the Dell 2007FP https://www.retrorgb.com/arcooda-20-240p-arcade-monitor-review.html 1 Quote Link to comment Share on other sites More sharing options...
tthurman Posted November 17, 2022 Author Share Posted November 17, 2022 Quote I recently reviewed the Arcooda 20″ LCD “arcade monitor” and while I really liked it, I wished there was an easy way to use it on a desktop; The monitor was designed to mount in an arcade setup and doesn’t have a VESA bracket. Luckily, Ludo has us covered and created a 3D printed slip-on stand pair that can allow you to easily switch between horizontal and vertical rotation! The short video above walks you through what you’d need and check out the links with more info below… Links and more over at Bob's. Quote Link to comment Share on other sites More sharing options...
