Databasemanager has a feature for visual pinball, to create the vbs scrpt and edit it outside visual pinball., But you can also right click on a vpx, and select "edit". This will open the editor without launching the table
Thats properly something in the table itself.
Mostly the author should take care of this, but you can remove it as well, by finding the correct materials in the table file and move the outside the point of view, or hide the elements via de script.
Or do you mean the texts on the backglass, because they should show it
3 hours ago, pdiavolikis said:
Thx a lot and one more question ...when i play the table i have text on my screen ..''balls 1 to 3''... ''shoot again''... ''game over''...how can i remove them ?
Post a screenshot if Mikes advice doesn't fix it for you.
