[RESOLVED] pinballx with vpx 10.7 running pinup player
I could be theconly people with this problem. it seems that when running pinup player inside of pinbalx, pinup player will not close when I exit the table, but does out side of pinballx, it works fine with vpx 10.6 so im a little confused to what is going on . hope some one can help shed some light on the issue.
thanks
I've not noticed any issues.
Are there any differences in the exe properties between 10.6 and 10.7 on your setup (under compatibility settings, things like run as administrator)?
Regardless, this .bat file used as a Launch After in PinballX should do the trick for you; https://forums.gameex.com/forums/topic/25060-resolved-pinuup-player-not-closing/?do=findComment&comment=197381
There is also a program called "pupcloser.exe". This is created by nailbuster itself.
You can run this tool on table exit as well. I only have a few pup tables, but all works fine with pbx and vp 10.7, without running any programs after the table exit
  • 1 month later...
  • Draco1962 changed the title to [RESOLVED] pinballx with vpx 10.7 running pinup player
