When I am in landscape mode and start pinballx the game menu is upside down. If I use the insert coin button I can rotate so it is either of the 4 directions. The tables load correctly, but how do tell pinballx which direction I want as default orientation?
Definitely one of those many situations where attaching copies of the support files (pinballx.ini and log.txt files) when posting an issue would likely result in an answer vs. more questions and answers. ðŸ˜Ž
