Hey Gang,
I have a bar-top cab running about 100 titles.  It's annoying when the attract mode repeats titles over and over.  Is there any way to have it run through them in order?  Thanks in advance.
Cheers
I think the purpose of attract mode is to do a randomize.
Maybe you can ask a feature request to Tom to add a setting, so you can choose between attract mode in order or randomize the tables
Thanks, it's not that big of a deal.  Just asked in case I was missing something (or a plugin).
Not sure if i understand correctly, but if it's the voice telling you the game names you mean then that is a plugin (in PluginManager uncheck the box next to 'Speak Game Names' to disable it)
Otherwise, Mike is right, random order of selected tables in Attract mode is currently the only option.
