[RESOLVED] Problems with table if you load with Pinball X ... please help me.
Hello and thank you for your great work and for your help.
Please help me solve my problem.
I have almost finished building my virtual pinball machine, the computer that manages everything is like this:
Motherboard Asus ROG Strix B450F, CPU AMD Ryzen 7 2700, RAM 8Gb Crucial Ballistix 3000 Mhz DDR4, HD M2 Samsung 970 EVO Plus.
Pinball X version installed is 5.41, Visual Pinball version installed 10.7.
I'll tell you what my problem is and please ask you for advice and help.
For example, if I enter the folder c: \ Visual Pinball \ Tables and start the table 1-2-3 (Talleres de Llobregat 1973) .vpx everything is fine and the ball moves perfectly, if instead I start the front- end Pinball X and select the same table when I start playing the ball jerky.
I have done other tests with other tables, some have the same problem and others work fine.
Can anyone please give me some advice to solve the problem?
Many thanks
Alessandro from Italy.
PinballX.ini
Hard to tell based on your story.
Whats your gpu ? And can you post your pinballx log.txt as well ?
I would recommend to check your VP visual settings (or add a screenshot as well). Als run a vp table from vpx, hit f11 on the keyboard and should show your fps.
Finally check your windows taskmanager during game play. Check if cpu/gpu or mem has a bottleneck.
Hi Mike_da_Spike,
thank you for the answer you have been very kind.
Here is the information you asked me, I hope I have given you the right information.
Video card: Asus GeForce GTX 1650 tuf 4gb
Thanks again for your help and the time you are giving me.
See you soon Alessandro
The 183 fps, is that launched from pinballx or directly launched ?
Not sure what kind of monitor you have, but I would limitvthe fps to your screen. If you have nsync (or freesync) monitor, limit the fps to your monitor.
I also prefer to enable exclusive full screen mode.
You mentioned you have an gtx 1650, but according to the log, it is an AMD hd5800. :blink: (and the vp screenshot shows a gtx as well)
That's right the 183fps is when I launch from Pinball X, the fps are always high, but the ball continues to stutter.
I have a Hisensa 4k tv, how much fps do you recommend to limit? (I hope the tv settings allow it).
before I had inserted an old video card (AMD HD 5800), but now I have inserted the GTX 1650.
Strange that it still remembers the old video card?
Do you advise me to delete the log.txt so that Pinball X creates a new one?
Thank you
Your TV will most likely be 60hz. In Visual Pinball video preferences try setting FPS Limiter / Vsync to 1 (which will lock FPS at 60 to match your TV refresh rate). Most people also set max pre-rendered frames to 1 as well, so also try that with 1 and 0.
These values;
Also try checking the Force exclusive Fullscreen option in VP video preferences (again, try it with combinations of the settings above)
Not sure when you changed the card. Just open PinballX again and launch a table, and that will create a new log file.
I recommend to remove the Amd drivers. https://www.amd.com/en/support/kb/faq/gpu-601. I never used this tool, so don't blame me if it is not working
Anf for the rest , i agree with scutters (i always agrees with him). Limit the fps to 60 fps if you use a tv.
  • Draco1962 changed the title to [RESOLVED] Problems with table if you load with Pinball X ... please help me.
  • Draco1962 locked this topic
