I have no idea how I did it, but when I load Pinball X and its cycling through the Systems, whenever I get to Visual Pinball, a synthesized voice says "Visual Pinball X".  I've checked everything I can think of and can't find the smoking gun.  Any ideas?
I appreciate any assistance!
Just now, Mike_da_Spike said:
Not 100% sure, but isnt this a plugin ?
I will double check but I thought I only had Scutters loading vid plug-in.
On top of my head, it was a plugin or setting. Wil check later on for you
EDIT: If it is only for your PinballX system, my assumption is that you have a file called "- system -.mp3" in your Media\Visual Pinball\Table Audio folder.
Edited by Mike_da_Spike
added extra assumption
  • Thanks 1
MIKE!!!  You're my hero brother!  I dont know how that file got there, but sure enough, that was the issue.  Thank you!  Was driving me nuts
  • MrGrynch changed the title to [Resolved] Speaking System Annunciation
