Can you add a 2nd mame system on to Pinballx  I want to have shooters and racing games separate, when I try adding a 2nd Mame with a different system name nothing shows.
Please attach your PinballX.ini file and log.txt files.
Can you also give a bit more information, where does nothing show (not showing in game manager/database manager, or have you added games but see nothing in PinballX)?
If you create an extra system, the extra system name will change as well. Old mame willstay. You can create custom database as well. That willbe a subset of the main Mame and can be selected via the menu -> lists . Another option would be to create a filter.
Add allshooters to the Mame, set for example the 'type' field to Shooters and create a filter on "type"= shooter.
This will be availabe in the Lists menu as well (all is in the pinballX manual). I think the database manager manual will also explain filters , groups and custom databases
