So I added a game to my Atari 2600 list but I forgot and had originally set "Hide Update List" to YES and set my filter to only show ".a26" files so I needed to make a couple of simple adjustments. So I went in and set "Hide Update List" to NO and made the rom filter ".a26, .bin". Simple right? Well I realized I like to use my scrolling mouse but that changes settings if the cursor is over a setting ... so I have no clue what I changed.
Loading GameEx now makes it go directly to my Atari 7800 game list which I think is EMU_2, there's no longer a menu at the top and I cannot back out (hitting BACK loads the exact same screen). It's like Atari 7800 is all that exists and it goes right for it. I'm just hoping it's something simple I am missing and I don't have to reinstall. :)
GameEx.iniFetching info... log.txtFetching info...
Going to bump this once and see. I'm getting the feeling an .ini delete or full install is in my future. TIA. :)
Have you tried loading the Setup Wizard to see what populates in it? Maybe make a change, advance to the next section then go back, revert the change, then proceed forward again?
May also need to delete the cache files.
  • Thanks 1
I honestly think I have gone through this line by line but I can't see anything obvious. I'm going to go full install tonight or tomorrow. My backup on the arcade cabinet is older than my grand daughter. Silly me...
EDIT: I was just about to wipe the files out and I noticed this little nugget below. This file is awesome! I don't know how I missed it in the directory.
  Quote
GameEx.UpgradeBackup.ini
It was 4 months old but everything is back the way I had it. Hopefully this helps someone in the future. :)
  • Draco1962 changed the title to [RESOLVED] Made a change and now I'm stuck
