Hi Folks
When I launch Friday 13th from PBX the playfield doesn't show on my monitor. The game is running but I just get a black screen. I can see the backglass and DMD.
If I go into VPX and uncheck "Force exclusive full screen mode" it does.
It works fine when starting from VPX via the OS in either mode.
I'm not sure if this is a table issue or because it is the only one I have with FlexDMD running.
I have VPX V10.7 and PBX V2.5 (I know this is very old but it works fine otherwise. I have tried to upgrade a lot of times and had many issues)
Any help appreciated.
Mirkin
Sorry, but pbx 2.5 is really out of support.
I have friday the 13th running on pbx 5.41 and doesn't have issues (vpx 10.7 as well, running full exclusive mode)
Sorry, not able to help
 What kind of issues you bump into when upgrade pbx ?
Hi Mike
I find that all sorts of crazy things happen.
Tables won't load. Vpinmame doesn't load/crashes.
These things happen after I upgrade even if run tables from VPX without PBX.
Do you have any idea what might cause these things?
If the tables won't load outside PinballX then it's unlikely it's a PinballX issue.
I think you'll need to try the update again, your issue may have already been resolved in one of the many revisions since v2.5. It sounds like it's a focus issue and you could probably ALT+TAB to bring the visual pinball player (VPX) window to the front, if that's the case then it is probably something that's been fixed.
  On 3/28/2022 at 6:57 PM, Mirkin said:
I tried Alt tab but that didn't work.
I'm going to do an update when I feel brave enough.
I'll report back!
Make a full copy of your pinballx directory !
A couple of mo ths ago, i was brave to reinstall windows on the cab, but only with a good backup it made a success
