Since I have video screens showing the system, is there any way to get rid of the system overlay?  I like having the wheel image so I know whats coming next, but the big overlay image is blocking the display.  I was thinking I could define one for the system that is blank?  I'm sorry if I am using the wrong term "overlay" here.  The attached picture shows what I am talking about. Part of the learning curve in all of this is learning the terminology.
Thanks for any help!
Thats the default how pinballx is working. The system/wheel is always showing what the current table/system is and what the prev 2 and next 2 are.
If the wheel is in conflict with your video, you need to adjust your videos or use underlay/overlay to make your wheel more to the front and sepperate it from your video
Not tried it, but you could probably just create a blank/fully transparent wheel image for the system, which is the in media\system logos for the systems menu.
But then you wouldn't have the system logo available elsewhere in PinballX (if you use it)
I understand the purpose of the wheel, however, my system is only ever going to contain 3-4 systems max, so scrolling through them is not a problem.  If the main playfield shows the currently selected system, then I don't really need that huge system logo.  If there was an option to keep the logo small, that would be good.  Gives more flexibility on cabinet design
I tried the transparent image and it works!
1 minute ago, Mike_da_Spike said:
Looks pretty awesome ! Nice cab
Thanks!  Just a few more tweaks on the frontend and it should be complete. The rest is just grunt work for the individual games/tables.  I'll create a thread in the builders forum soon, as well as a video link to a walkthrough of the build
  • MrGrynch changed the title to [Resolved] Removing Unwanted Graphical Elements
  • Draco1962 locked this topic
