The complete PinballX Documentation
View File
The complete PinballX documentation to setup your Pinball cabinet.
All the options/screens are explained how you can modify PinballX to show what you want.
Thanks for the previous persons that worked on the document.
I received the template @Draco1962and used an old version of the document (Thanks to @zeenonwho created the first  version of the documentation)
I re-used some texts, but most I completely re-create on a PC that didn't had PinballX on it.
It took me around 4 months to get it all together.
Version of document is the latest version of PinballX on date of publishing this document.
All the features that are described in the document are available in the same version of PinballX
Any new features of new releases should be added
  • Thanks 1
  • Draco1962 changed the title to [GUIDE] The complete PinballX Documentation
  • Draco1962 pinned this topic
  • 2 months later...
  • 7 months later...
Updated documentation to PBX version 5.83
Custom filters (INI files) can now also support AND(&) and NOT(!) in the string
Combination of AND and OR is not allowed, but a NOT can always be in front of a wildcard (*)
See examples in the documentation :
The following will show all tables where Stern is in the search criteria
*Stern
The following will show all tables where Stern is NOT the search
criteria
!*Stern
The following will show all tables where Stern AND Gottlieb is in the
search criteria
*Stern&*Gottlieb
The following will show all tables where Stern OR Gottlieb is in the
search criteria
*Stern|*Gottlieb
The following will show all tables where Stern AND Gottlieb are both
NOT in the search criteria
!*Stern&!*Gottlieb
The following will show all tables where Stern OR Gottlieb are NOT
in the search criteria (This would results in all tables, as you search on
NOT Stern OR NOT Gottlieb)
!*Stern|!*Gottlieb
  • Thanks 1
  • Draco1962 changed the title to [GUIDE] The Complete PinballX Documentation
