Tables will not load from wheel on older PinballX
Hi,
I messed up my hd containing my tables really badly.
i was able to restore from a backup,, but now i cannot launch any tables from my wheel (they show up with backglass but wont load cycles back again)
I  have a log shown here (very short for some reason)
thanks for any help in advance
it is PinballX old version
Very short log file
12:58:57.5  2/8/2022:  PinballX - Version 2.42
12:58:57.5  2/8/2022:  Windows 7 Home Premium Service Pack 1 32-bit (3.4GB)
12:58:57.5  2/8/2022:  Loading Settings
12:58:57.5  2/8/2022:  Initialize Component
12:58:57.5  2/8/2022:  Initialize Display
12:58:58.6  2/8/2022:  Loading PlugIns
12:58:58.7  2/8/2022:  Created DirectX BackGlass Window
12:58:58.8  2/8/2022:  Created DirectX DMD Window
12:58:58.8  2/8/2022:  Hiding Cursor
12:58:58.8  2/8/2022:  Hiding Taskbar
12:58:58.9  2/8/2022:  CPU:  Intel® Core™ i5-3470 CPU @ 3.20GHz
12:58:58.9  2/8/2022:  GPU 1: AMD Radeon R7 240
12:58:58.9  2/8/2022:  Displays: 2
12:58:58.9  2/8/2022:  Load Game List
12:58:58.9  2/8/2022:  Loading Database: Pinball FX2
12:58:58.9  2/8/2022:  Loading Database: Future Pinball
12:58:58.9  2/8/2022:  Loading Database: Visual Pinball
12:58:58.9  2/8/2022:  Loading Custom Database: Visual Pinballold
12:58:59.0  2/8/2022:  Finding and matching artwork and videos
12:59:06.4  2/8/2022:  Loading Game Statistics and Scores
12:59:06.4  2/8/2022:  Main display running full screen windowed.
12:59:06.5  2/8/2022:  Loading Surfaces
12:59:06.7  2/8/2022:  Finished Loading Surfaces
12:59:06.7  2/8/2022:  Initialize Audio
12:59:06.7  2/8/2022:  Set Keyboard Controls
12:59:06.7  2/8/2022:  Initialize Joystick
12:59:06.7  2/8/2022:  No Joysticks Attached
12:59:06.7  2/8/2022:  Started
12:59:11.4  2/8/2022:  Launch System
12:59:11.4  2/8/2022:  Waiting for threads
12:59:11.4  2/8/2022:  Disposing display
12:59:12.6  2/8/2022:  Writing ScreenRes.txt
12:59:13.4  2/8/2022:  C:\PinballX\Scripts\ledset.bat
12:59:17.6  2/8/2022:  Created DirectX BackGlass Window
12:59:17.7  2/8/2022:  Created DirectX DMD Window
12:59:17.7  2/8/2022:  Main display running full screen windowed.
12:59:27.4  2/8/2022:  Exiting
12:59:27.4  2/8/2022:  Showing Taskbar
12:59:27.4  2/8/2022:  Unhiding Mouse Cursor
12:59:27.5  2/8/2022:  Disposing Plugins
12:59:27.5  2/8/2022:  Saving Settings
12:59:27.5  2/8/2022:  Bye
I moved your post to the correct subforum for better visibility.
Please attach copies of your pinballx.ini and log.txt files (no copy and paste).
With such an old version you will likely need to upgrade to the latest version in order for us to be of help.
My guess will be that pinballx cannot find the table you selected and wont launch it.
Is the same happening with fx2 ?
As you run more than 250 vetsions behind the current version, i would say to upgrade pinballx as wel.
You can also try databasemanager to check your systems and your visual pinball and future pinball tables. It will check if your paths are ok and check if the names of the tables file corresponding to the xml
