The credits for this plug-in goes completely to Swisslizard.
This is a slightly modified version, that will give more hits on tables for the led matrix .
Avoiding a lot of log entries with 'Event_Input' lines
Added some extra log lines, when a led matrix doesn't show anything.
This could be that the table doesn't match a rom that is setup in DOF
Or the table doesn't have an 'PF Back PBX MX ' setup in DOF (or some other cases.
It helped myself out why some table had a Led Matrix working and some didn't (although it was matching with a rom)
Copy the DLL in the zip to your pinballx\plugins.
Run PluginManager.exe from your pinballX directory to enable/configure the plugin
  • Thanks 1
  • Mike_da_Spike changed the title to [PLUGIN] PinballX DOF 1.2 (Swisslizard Modified)
Small Update on the file.
If you are adding ROM names in your table XML file, it will first try to match on the rom.
This can give a better hit than the description name, and would avoid tables with multiple entries to pick the first one.
For example ACDC :
22.01.03 01:08:10.726 Best match for ROM acd_170hc is ACDC LIMITED EDITION (acd_170h). Match Value: 0,888888888888889
22.01.03 01:08:10.726 Game selected AC/DC ???? (Update sent for ACD_170H)
22.01.03 01:08:14.637 Action: PBXWheelLeft
22.01.03 01:08:14.887 Action: PBXGameSelect
22.01.03 01:08:14.891 Best match for ROM acd_170c is ACDC (acd_170). Match Value: 0,875
22.01.03 01:08:14.891 Game selected AC/DC ???? (Update sent for ACD_170)
See the difference between rom acd_170hc and  acd_170c and the entry it takes from the DOF config tool
Adding rom names, will be done automaticlly on most tables with database manager (thanks to @scutters, who implemented this a long time ago)
  • Mike_da_Spike changed the title to [PLUGIN] PinballX DOF 1.4 (Swisslizard Modified)
Updated to version 1.4
Thanks to Angrim to update the DOF tool for me
Most important function is that a default led MX will bw shown when no matching table is found (instead of a black MX screen)
you can change it yourself by changing the PinballX MX 'table'
  • Thanks 1
