Bonjour,
L'accès FTP me donne sans cesse
Réponse :    530 User cannot log in.
Erreur :    Erreur critique : Impossible d'établir une connexion au serveur
? HELP
First, I moved this thread to the correct forum. Please do not post a request for assistance in the FAQ forums!
Second, please post in English (refer to the Forum Rukes & Guidelines).
Third, refer to this News post and ensure you are using your email address and password associated with your forum account:
Let us know how you get on. Thanks.
I See this message, but, Is there a topic config filezila?
Result :530 User cannot log in.
Please
https://hostingjournalist.com/filezilla-530-login-authentication-failed/
You must not be using the correct credentials per the error description linked above.
Make sure you are setting Filezilla to the following:
Server: ftp.gameex.com
Port: 21 (not shown in your screen capture)
Connection: Explicit FTP over TLS
User: Your email address for these forums (same for GameEx Online).
Password: Your forum password
For testing your credentials you can try Databasemanager.
Open settings, go to the GameEx tab, full in your email address and password. And hot the check access button.
Quote
From https://forums.gameex.com/forums/ftp/
Port: 21 (Default).
User: Your username email for these forums (same for GameEx Online).
Password: Your password here
It may be worth updating the above page for those who didn't see the 21st September update from Tom. I can get in with my email address. Thank you for advising about the change.
7 minutes ago, bombdog said:
Quote
Port: 21 (Default).
So @bombdogwere you able to connect?
