PinballX works fine though I've noticed a weird issue.  If I leave it running in attract mode, it eventually stops showing anything on my second monitor (the backglass).  It requires that I press a flipper button to switch to a new table for anything to reappear.  Any ideas?  Most of my backglass are animated or otherwise have graphics or video that you would think should interrupt any power management sleep function.  It also doesn't appear that the monitor is in any hibernation mode since when I switch tables it immediately shows the new table backglass.
Can you please attach you pinballx log file and the file pinballx.ini. the logfile should be created after you simulate your issue
Don't see anything strange in your log file.
maybe there is a corrupted backglass video that is causing this behavior ?
You are running a couple of versions behind as well, but don't think this will solve it (but I will always download and use the latest version)
3 hours ago, echodun said:
How do I update to the new version without losing all of my settings?  I think I'll try that route at least.
Just install the latest version straight over the top of you current install. Media and settings will be preserved. https://forums.gameex.com/forums/files/file/527-pinballx/
LAV codecs - https://forums.gameex.com/forums/files/file/2451-lav-video-codecs/
