PinballX will not start.
Here's the LOG.txt
19:07:07.32  11/19/2021:  PinballX - Version 4.80 x64
19:07:07.38  11/19/2021:  Windows 10 Pro 64-bit (32GB)
19:07:07.38  11/19/2021:  Loading Settings
19:07:07.43  11/19/2021:  Initialize Component
19:07:07.44  11/19/2021:  Initialize Display
19:07:07.51  11/19/2021:  Testing Flash engine.
19:07:08.57  11/19/2021:  Loading PlugIns
19:07:08.58  11/19/2021:  Loaded Plugin:"Xpadder Plugin" Version 1.0.1 By Adultery
19:07:08.63  11/19/2021:  PlugIn: "Xpadder Plugin" Initialized OK
19:07:08.63  11/19/2021:  Using Plugin System Version: 1
19:07:08.68  11/19/2021:  Error. Exiting
19:07:08.68  11/19/2021:  An error occurred creating the form. See Exception.InnerException for details.  The error is: Class not registered (Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG))
19:07:08.70  11/19/2021:     at PinballX.My.MyProject.MyForms.Create__Instance__[T](T Instance)
19:07:08.70  11/19/2021:     at PinballX.My.MyProject.MyForms.get_BackGlass()
19:07:08.70  11/19/2021:     at PinballX.FrmMain.InitDisplay(Boolean FullScreebWindowed, Boolean InitialLoad, Boolean IsIngame, Boolean WasLost, Boolean NoLog, Boolean CalledFromSelf, Boolean DontDisposeBlackForm)
19:07:08.71  11/19/2021:     at PinballX.FrmMain..ctor()
19:07:08.71  11/19/2021:  Disposing Plugins
19:07:08.71  11/19/2021:  Showing Taskbar
19:07:08.71  11/19/2021:  Unhiding Mouse Cursor
19:07:08.71  11/19/2021:  Bye
Can anyone help me with this??
Can you attach (no copy & paste) your pinballx.ini please?
Also, can you try an updated installation of PinballX? Current version is 5.22 and this may resolve your problem.
Thanks.
Looks like you copied a pinballx installation,  instead of installing.
As Draco said: upgrade to latest version, run settings.exe and go through all pages.
If anny issues occurs, please attach the files and not copy the text
12 hours ago, Tom Speirs said:
Fixed some time ago. Please upgrade.
Is there an easy way to upgrade, and preserve all my settings?
I can’t even launch PinballX to start the automatic update.
You download the latest file and perform an "over the top installation." This will preserve your settings. You may want to locate and save the pinballx.ini file to a separate location if you have any uncertainty.
