Hi, really hoping for some help, using PBX 32bit - when I launch a FX3 table via the desktop icon  DOFLinx kicks in all is fine - everything works, however when I launch FX3 from PBX everything except my addressable led lighting works - using the steam version of FX3 set to offline mode , has anyone encounted this issue and can help??
Is there something I need to do to get the led matrix and strips to fire - dof has all the xml files including globalconfigxml, I use a pinscape for my toys and a teensy for lighting, its the lighting only thats an issue.
I need to check.  Using the 64 bit of pinballx, and pretty sure that my mx leds are turned on during fx3 and doflinx.
Will check tomorrow for you, and please provide indeed logfiles and settings files of pbx as draco said.
Also the version of fx3 and doflinx.
There is an option to create a debug log for doflinx and ddh69 is always willing to help
I checked for you on my cab, but launching  a fx3 table from PBX, launches fx3, with SSF anf DOFlinx
Please post the information we ask  to get better support
Hello, got PBX latest version, I use doflinx with future and fx3, when I first launch into fx3 everyhing works ok, I exit and start FP, everything works except my addressable lighting, if I then go back into FX3 and mx lights now dont work all other toys ok, I have to close everything , doflinx is still running, I close that and then restart it, restart PBX, goto future pinball launch game works fine, again when I exit and return NO LIGHTING again, but DOFLinx is still running?? I can only get mx working in fx3 is I run pbx as NON ADMIN, something is wrong but cannot work out what??
In a nut shell I can go to either FX3 or Future on my initial game and they will both work until I exit either of them and go back in..like I say DOFLinx does not close...whats the deal with that???
Is this the same issue as you mentioned in this post ?
It 8s a bit hard, to guess your issue. Please provide the info that is asked
I took the liberty of merging your two nearly identical posts. Please refrain from posting multiple posts for the same issue.
Also, you've been asked to attach copies of your pinballx.ini and log.txt files for review.
