One of my 25 configured tables does not exit to PinballX menu
Hi all,
I have a problem with one of the 25 configured Visual Pinball X tables in my van. It does not exit to PinballX using the mapped cabinet button. It shows the pause menu instead... After 10 seconds in this menu, not responding to any button, I can push the exit button again, then it returns.. have you seen something like this? It should be something in the table setting itself instead of the global Pinball X or Visual Pinball X settings as all other configured tables exit to PinballX fine.
Thanks in advance, Matthijs
IMG_15102021_001803_(1600_x_2560_pixel).thumb.jpg.47e9f4681ea7d78a3522617609d33c9d.jpg
  • mgslisser changed the title to One of my 25 configured tables does not exit to PinballX menu
Please attach (no copy and paste) copies of your pinballx.ini and log.txt files right after the error occurs.
Also, which table is acting up?
Logs and vonfig file will be appreciated, but looks like your exit key in pbx is the same as the quut key in visual pinball.
Same issue was lately mentioned on another forum as well and fixed to use another exit button/ key
EDIT:
Make sure you checked the "Disable ESC key" in Visual Pinball if ESC is your exit key in PBX
Why you only have it on a few tables, is a mystery for me, I have 994 visual pinball tables and all closes via the exit button correctly
Thanks, log and pinballx ini are attached. The log is after I pressed the exit button on the cab. Showing the pauze menu in the table.
The second log (copy, in dutch kopie) is the log after the table times out after a few minutes and then it returns to the pinballx wheel.
Kind regards,
Matthijs
ps. I do not have that disable esc checked! will experiment with that. However I do not use the keyboard. I will add a screenshot of the keys config
log.txt PinballX.ini
log - kopie.txt
Try checking the "disable esc key". Think i created my screenshot wrong... sorry for that
Your quit key in pinball is also esc.( Key code 27). So make sense to check it it visual pinball.
You use an key from keyboard to quit ?or a joustick button ?
