[RESOLVED] V5.19 not showing apng in DBmanager & exit question
Hello,
just installed 5.19, great it has animated wheel (.apng) support however the game manager tells that the Wheel is missing in the list although it is assigned and in PBX itself it shows fine,
So it is just the game manager : both it says it is missing (under the dropdown menu) and it is not showing  the wheel (only in manager, as said,  when running PBX 5.19 it is fine)
Then: when exiting now there is an option to totally reboot the PC!
Didn't have it with my previous version and I really do not want that.
Is it possible to disable this function (plus I do not see why there would be such a drastic functionality with PBX anyway, very user_unfriendly...)
Thanks!
Personally i use Database Manager instead of Game Manager, you could try that instead, it adds a lot of functionality on top of Game Manager.  Otherwise a change to Game Manager will need Tom to look at.
That one's simple, open Settings and go to the Exit Screen section, just set Enable restart to No.
Thanks for your help!
Found the option in the menu, disabled it and it's gone. (I was trying to find it iin some xml_file without succes but it was much easier :-) )
The not-showing in the game manager is a bug I guess, not a big problem as I do know when adding tables I need to add a wheel and will defenitely miss it when running PBX but just a minor thing.
Again, thanks and will have a look at the PBXdb manager!,
  • Draco1962 changed the title to [RESOLVED] V5.19 not showing apng in DBmanager & exit question
