Please attach your pinballx log and ini files.
If you have launch before or after batch files enabled for FX3 please also let us know what they do.
Odd.
Your 2nd screenshot, is that pinballx or fx3 ? I can't see it correctly.
And as Scutters says, please attach your files
  On 7/4/2021 at 9:10 PM, scutters said:
Per favore allega il tuo log pinballx e i file ini.
Se hai avviato prima o dopo i file batch abilitati per FX3, facci sapere anche cosa fanno.
Vuoi estendere le Senza titolo.png.473bcf113152d0a6ad68f7b357882c1b.pngfunzionalità?
    Prova
PinballX Database Manager  in sostituzione di Game Manager per gestire i tuoi giochi e i tuoi contenuti multimediali (grazie a@Mike_da_Spike)
    Usa i
plugin per aggiungere funzionalità come il caricamento di video per tabella, lettore multimediale/musicale o funzioni di visualizzazione dei punteggi e delle statistiche più alte
here is my .ini file
Can you also post your log file after the issue occurs?
Edit : I see you use not the legitimate version of FX3 but a cracked version. Did this ever worked for you, or is this from the begin you set this up ?
(And to be honest,  I think it is not fair against the creators to troubleshoot a cracked version)
  On 7/5/2021 at 8:31 PM, scutters said:
No attachment. Did you remove it?
Want to extendUntitled.png.473bcf113152d0a6ad68f7b357882c1b.pngfunctionality?
    Try
PinballX Database Manager as a replacement for Game Manager to manage your games and game media (thanks to @Mike_da_Spike)
    Use
Plugins to add features like loading videos by  table, media/music player or high score & stats data display functions
Think so. I checked it
