Hello
This seems to be an issue sometimes when I clone my drive for back up purposes.
It doesn't seem to matter what screen I set the playfield to, it will only show on the backglass or DMD. (3 screen setup)
Once I load VPX, everything is fine. This is a front end issue only. PBX just doesn't want to move to my playfield (Windows ID#2)
In Windows, Playfield=2, BG = 1, DMD =3.  This setup has always been fine. My playfield doesn't have to be #1.  (PF - GPU - HDMI. BG - GPU - DVI.  DMD-Onboard-VGA)
Everything seems fine visually, I'm not brand new to this. I have had, and fixed this before but can't remember what I did.
PBX 5.02 freshly installed, no change.
I can get logs etc from the vpin if needed/helpful.
Thanks everyone!
I edited the config file to match the resolution of the playfield screen (it was set to 1920x1080). That seemed to be the issue??? Resolved for now.
  • Draco1962 changed the title to [RESOLVED] Can't force PBX to 'playfield' monitor
