HI Tom,
I just upgraded to 5.12 tonight as Windows 10 updated and I had a flash.ocx error where my previous build wouldnt start.
Anyway, 5.12 seems to work fine in the main menu, but when I go to my favourites list (only 47 VPX tables) the backglasses dont reload on changing tables, i.e they are stuck on previously scrolled tables. This doesnt happen on the main menu.
This list was created using an older version obviously, but which one I cannot say.
Anyway, otherwise, it seems to be working well.
Cheers
Edited by Draco1962
Moved to correct subforum from GameEx > General to PinballX > General
Hi,
Id need the log and pinballx.ini at the minimum to try and troubleshoot. In this instance a video would help too.
Tom.
PS: I suspect your using B2S backglasses actually within the front end? Honestly I rarely test this feature if so. Your better using videos.
  • 2 months later...
Sorry for the delay Tom, ailing health.
Anyway, yes I am using B2S backglasses for the most part, I have updated now and doesnt seem to be as much of an issue. If I scroll fast it does get stuck on a previous backglass.
My question then is, for the tables which I use a static image (PUP Tables like Munsters, Guardians and now Batman 66) the image stays up behind the table. Not a big issue, but is there a way to close these images down?
Thanks.
J
Please make sure you are upgraded to the latest version and attach copies of your pinballx.ini and log.txt files in reply to this thread.
