[RESOLVED] Pinball FX3 - PinballX won't launch directly into the tables.
Three screen cabinet.  No add ons.  Pretty basic configuration, I think.  Just had this problem appear tonight.  Everything was fine last night.  Frustrating and perplexing.  No changes were made to settings.  I made sure to update to the latest version of PinballX.
Anyone else have this problem?  It just started today.  It's hard to narrow down what the cause is because I didn't do anything with the settings.  Could Steam or Pinball FX3 have made a change so that tables don't launch like they used to?  Then it would be happening to everyone, I would think, unless they knew how to fix the settings to get it working.   Everything else seems to be working normally.  FX 3 will start, but it won't go directly to the table I chose.    i can quit normally.
edit:  Thought I should add that Visual Pinball is working.  It's only FX3 that's doing this.
Do you have the Steam cabinet code set up in FX 3 ?
Without setting this up, you will not able to launch FX3 directly to a table
Pinball FX3 Cabinet Mode FAQ – Zen Studios
Misread your question. I will check mine now ....
Mine is still working. Maybe try to reactivate your PAC within FX3.
EDIT :  Should the parameter -table between double quotes ?
I use Joyriders launch script, and that paramter needs double quotes :
Thanks for trying to help, Mike.  Turns out the problem wasn't so much with PinballX.
For some reason cabinet mode was deactivated and that also took away the ability to launch directly to a table.  I didn't notice right away because I hadn't bothered to check that box in table manager that turns off the backglass when I'm playing a table for a lot of tables.  I nevere bothered because normally the PinballX backglass got covered up by the FX3 backglass while I played anyway.
That made it not so obvious that cabinet mode wasn't active though - I still saw that there was backglass up.
When I tried playing a table without using Pinball X it was obvious right away - no backglass or DMD.  Found my code to enable cabinet mode, entered it again, and now everything is fine.  Mystery solved.
I had that once as well ( thats why i mentioned the pac as well)
I use DOFlinx for background and didn't update it since last FX3 update, so I have black background as well
Glad it is (quickly) solved
  • Draco1962 changed the title to [RESOLVED] Pinball FX3 - PinballX won't launch directly into the tables.
  • Draco1962 locked this topic
