Pinballx skips(jump) tables
starac
If I use the keyboard everything is ok, but over the pinscape controller([JOYCODE_1_BUTTON6] or( [JOYCODE_1_BUTTON5])left to right skips the table....He skips 3 table or 2 jump...
Strangely I can't choose a certain table he just skips the tables ..he chooses at his discretion
On all versions pinballx
Link to comment
Share on other sites
Do you have magna save (page) buttons mapped the same as left/right flippers?
You need to attach your log.txt and pinballx.ini files!
Also, is this is new controller (and buttons ok in game etc)? Thanks
Link to comment
I have had a look, the repeat rate is 600 milliseconds which should be plenty.
However it is global across all buttons/directions.
So I suspect the issue is because you have a button held down or  there is an issue with getting the system tick count but this would screw up a lot of things.
Link to comment
I had the same with my vpincontroller.
My switch of my 2 euro coin chute was "pressed" (it was stuck and the button was constantly pressed)
I didn't noticed anything, but PBX behaved steange when I wanted to go to the next table. Every menu item selected multiple entries.
Checking my joy buttons in windows, I noticed 1 was pressed. Fixing that dipswitch, al was working fine for me
Link to comment
