Mike Iacaruso Posted March 23, 2021 Share Posted March 23, 2021 I have a VPX/PinballX setup working on my cab and I want to add Future Pinball to the mix. I installed Future Pinball and everything is working great. I can add the FP tables to the game manager but when I start PinballX I do not see them, just the VPX tables. Am I missing something here? I am running the latest version of PinballX. Thanks Link to comment Share on other sites More sharing options...
scutters Posted March 23, 2021 Share Posted March 23, 2021 Please attach your Pinballx\config\PinballX.ini and Pinballx\Log\Log.txt files so we can see the details of your setup, otherwise it's just guessing! Link to comment Share on other sites More sharing options...
Mike_da_Spike Posted March 24, 2021 Share Posted March 24, 2021 You properly miss something, but as @scutterssaid, without tbe ini and log file it is just guessing. Btw , Did you know that Databasemanager has a filter, so that not enabled systems, will be hidden ? With this option, you can easily check if you setup a system correctly and that it will be showed in PBX Link to comment Share on other sites More sharing options...
Mike Iacaruso Posted March 24, 2021 Author Share Posted March 24, 2021 Here are the INI and log files. Mike_da_Spike I have the FP tables enabled in gamemanager, I am not familar with databasemanager. Where is this located? Thanks log.txt PinballX.ini Link to comment Share on other sites More sharing options...
scutters Posted March 24, 2021 Share Posted March 24, 2021 You have one click launch enabled, so you don't see a menu appear when you select a game (the menu allows you to change between game systems and lists). You could also show the system list at startup if you want where you could select future pinball as a system These two settings; PinballX Database Manager is a replacement for the game manager that comes with PinballX. You can download it here; The app comes with a pdf file that should help you, or there's a support thread with more information. I think it's pretty darn good (but i may be a little biased! ) 1 Link to comment Share on other sites More sharing options...
Mike Iacaruso Posted March 24, 2021 Author Share Posted March 24, 2021 Thank you very much, I will update my settings and take a look at the database manager. 1 Link to comment Share on other sites More sharing options...
