Input lag on some systems, opinions needed, please.
So i just finish building a game for a friend, now, this particular friend , is an old guy, 53 years old.  Now this friend aint no gamer, not even a computer type of guy, so , before i made his game, he went to a another friends house to test the game to see if he really wanted one, and he told me, he feels some input lag on the flippers, the owner does not feel that way.Anyway, today he came to pick up his game, and he insisted that he feels on some games he can feel the lag, you know when you push the button and the flipper acts, he says there is lag. Now i really dont use modern hardware,  i5 3rd or 4th gen, amd firepro 512mb,8gb ram. With that kind of hardware, visualpinball runs just fine, vpx a little slow ,fx2 and 3 run fine and futurepinbal runs nice. So he says, that on the fx3 and fx2 and visualpinball, thats where he feels the lag, the other systems that run slow, he says  they dont have the lag. Now to be honest, i dont feel a lag on any of them, could it be im used to input lag? my other friend plays just fine too. Or maybe the faster games are to fast for him? what do you guys think? is there something that can be done to slow down the systems that work just fine? thanks for any advice.
Can I remind you that 53 us not really old for pinball nerds?
Lag can come because of the playfield settings. Or even the response time of your monitor/tv.
So, not sure what you use for playfield. Sometimes tv's has a console input setting , that will skip some upscaling chips in the tv, that will goes faster.
Nice cabinet btw !
  • Thanks 1
Nice cabinet btw !
Also try  PinballX Database manager as an alternative way for gamemanger
well, its a regular 1080p 43 inch tv, i have the settings at 1360x768 playfield and 1280x1024 backglass, and like i say , i dont notice such lag. Im 44 by the way, play mame games alot, so i think if there was a real delay i should have noticed...
You do over time adjust to some level of lag, and some people are more sensitive to it than others.
Antialiasing / graphic settings (in game or gpu) may introduce some lag, but usually the main cause is screen processing. Activate the tv's game mode if you haven't already https://displaylag.com/how-to-enable-game-mode-on-your-hdtv/
Even with game mode active some tv's will still have noticeable lag when compared to a good monitor side by side.
10 hours ago, Mike_da_Spike said:
And always use hdmi 1.
Whats the playfield tv you used ?
Brand and type, to check what the specs are.
vios tv4317sm  i couldnt find much info on it, but the other guy is using  a vizio 43 inch 4k tv,, no lag for both of us.  I think, that he feels lag because he is not fast enough to act on faster games, but he does not feel lag on slower games , so he acts accordin to times on those slower games.
Ok.. well give him only old, slow tables .:lol:
If it is just the feeling, there isn't anything we can do about it
12 hours ago, ode1979 said:
vios tv4317sm
All i could find was this https://www.segundamano.mx/anuncios/ciudad-de-mexico/venustiano-carranza/audio-tv-video-y-fotografia/pantalla-vios-43-smart-tv-fhd-full-high-definiti-934728153
Pictures on that link show hdmi and VGA inputs, if you're using hdmi then switching to vga might be worth a shot. that might bypass tv processing and effectively be game mode. You might need a dvi - vga adatpter for your graphics card, not sure.
Otherwise all you can do is go through all the tv's menu options to try and find something like a pc or game mode.
Yes, turn off any kind of processing the TV can do if the TV doesn't have a game mode just turn everything off you can find that has to do with image processing.
Only just noticed this bit;
It's a while since i used a tv as a monitor, but i'm pretty sure having the playfield screen res set lower than the tv's native res will mean the tv is upscaling to 1080 as well.  Probably best to output 1080 to the the tv.
Didn't you have a 43" monitor with 120 or 144hz 4k screen with nvidia sync #mejelous
  • Haha 1
43", 4k, 120hz, Gsync  #smugmode :banana:
