Does anyone know the proper command line for CXBX Reloaded? I"ve tried launching it several different ways and it doesn't seem to work. If anyone knows the answer it would be greatly appreciated. Please and thank you.
Try this:
Change to romfilter=*.xbe
Change From: emu_46_command=cxbxr-ldr.exe /load
[ROMPATH]\[ROMNAME]\[ROMFILE]
To:
emu_46_command=cxbxr-ldr.exe /load "[ROMPATH]\[ROMFILE]"
Not sure what to tell you . It doesn't sound like it follows the typical conventions.
In some of the examples I have seen briefly researching Launchbox and other frontends, some have resorted to using combinations of AHK scripts to launch before and after.
You could use *.lnk  in the ROM filter after compiling an AHK file and launching via a shotcut to it (hence the .lnk) but you'd have to do that for each ROM file. At least it would have the absolute file path in the compiled script.
Wish could do more to help, Perhaps someone else that does will suggest a solution.
@Draco1962 Thanks for your help. I really appreciate it. That's pretty much what I thought. I'll see if I by chance the developer/s will off up anything. Thanks again.
