Hi again,
Another issue related to Pinball FX3. I have noticed that several tables have not imported to PinballX. I am running the Steam version of FX3 and the majority of the tables are showing up fine and working. How can I get the rest of the tables into the front end? I have tested the games standalone and they work fine. Just not sure how to make them import from FX3.
Thanks much!
This is not an automatic process. You have to load them via Game Manager or manually into your Pinballx FX3.ini file. This requires you to identify the Steam name for the tables in order for PinballX to launch them.
Well.. there is a program in the downloads section, called "database manager". This program will populate (if you have the steam version) all FX3 tables into your database file.
You only need to give it a propper display name
Hmmmm, I have been using Database Manager to setup the games with the table audio files etc. I saw some weird games in the FX3 list like Redcup 2 etc. But it didn't look like they were for anything in FX3 and there definitely weren't enough in the list to account for the number of missing games that are in my FX3 purchased games list.
If it isn't doing that, like it seems it should be, what would I look for?
Thats the beauty of Database manager ;)
I think the devs could not find a way to translate the descriptions , but Redcup2 is defintly a table.
Example :
RedCup1 = Star Wars - Solo
RedCup2 = Star Wars - Calrissian Chronicles
RedCup3 = Star Wars - Battle of Mimbam
So set it up like this, and it shows the correct display name with the correct table to launch :
See also the following thread that will show how easy it is to add Williams Vol 6:
