Last week volume 6 released.
See https://store.steampowered.com/app/1450220/Pinball_FX3__Williams_Pinball_Volume_6/
Was only €8.19 on steam (and not in sale). My wife also bought it on her Nintendo Switch for € 9,99.
Anyway ... I added 4k Flying video and HD Backglass videos (backglass created by DDH69)  on FTP :
/-PinballX-/Media/Pinball FX3/Backglass Videos
/-PinballX-/Media/Pinball FX3/Table Videos
Because Freezy DMD isn't working yet , I could not grab any DMD frames (and not sure if it is worth to capture the DMD frames as the rest of the DMD's I created for FX3)
See https://github.com/freezy/dmd-extensions/issues/258
You want easily add this to PinballX ?
See the following thread. Within a couple of minutes (or less)  you can have it added easily and mostly automated
Any one already has FX3 wheels created for the 3 tables ?
I use same backglass, audio and wheels for recreations in all systems.
FunHouse is FunHouse in VPX, in Future, in TPA, in FX3...
Only record new video for the table, for DMD I generally use the old Visual Pinball videos without color DMD.
Here you go.
NOTE:  THESE MAY NOT BE NAMED CORRECTLY!  Just got the pack and haven't fired it up yet or even looked so don't bitch if it doesn't work because you didn't read this.
I cussed...that was mean...but don't bitch.
  • Thanks 1
Thanks BrandonLaw, just what I needed.  I did all of the active backglasses, force feedback and MX effects almost on the day and now finally get around to adding them to my front end!
Finally got around to adding Vol 6...just making sure I'm not crazy by looking through the GitHub commits that Freezy's is still busted, correct?
Freezy’s  native grabber (non-legacy) works in Volume 6 but not with the 3 new alphanumeric tables. Also, in Volume 6, Freezy’s native grabber no longer correctly handles the color that FX3 uses (for example, in Jaws, the DMD is rendered with default amber dots even though the dots should be cyan).
Someone posted on github an fix for it, but I can't get it to work :
https://github.com/freezy/dmd-extensions/blob/master/LibDmd/Input/PinballFX/PinballFX3MemoryGrabber.cs
  • 1 month later...
  • 5 weeks later...
  • 6 months later...
Hi Guys and thank you for your amazing work - you've made my cab looking like i like it ;-) I'm still looking for the DMD Videos for Volume 6 tables - is this the issue with "Freezy"? Are there any backglass images on the ftp for the tables? Thank you in advance
Volume 6 is alphanumeric and not supported (yet) by freezy, so I wasn't able to grab the dmd and make a movie of it.
Think that freezy is busy with vpe instead of dmddevice.dll
Colors are not working either in fx3
Yes. Videos and images. With Databasemanager you can easily download them
