Hi eveyone,  does anyone have the table Corvette (midway 1994) 1.2 running pin pinball X,  it returns to the load screen without launching same with in Game manager trying to launch or take videos.  Have many other tables running correct but not this one.  It loads and play perfectly when directly done in VPX.   I did just try updating to 4.61 but I have the same results.  Every other table I added today worked perfect.
Thanks for any ideas
You'll probably need to attach your pinballx.ini and log.txt files (after an attempt to launch that table)
But to answer the question i do have that table and it works ok for me. I'd double check your vpx file name matches the entry in game manager / database xml.
Edit - and as a shameless plug, you might want to try pinballx database manager instead of game manager https://www.gameex.info/forums/files/file/2499-pinballx-database-manager/ ;)
Thank you,
I ended up just renaming the file to corvette.vpx and it started to work just fine,  renamed it back to above and it failed the same way.  Real odd but resolved thanks.
I'll checkout database manager as well.
