Hi guys, quite new to pinball x but have managed to get everything working with a couple of exceptions. FX3 tables load and run very quickly, VPX doesnt. After messing around I have realised the images in the backglass are the imported ones from my installation of VPX which have some very large files. I have all my small back screen files in the visual pinball backglass folder and have relinked them manually but the system seems to have cached the ones from Direct2bs from my VPX system and will not let me overwrite them. Where can I delete these files as I have tried looking through all the folders and cannot find anything?
Also is there a way to make VPX and FX3 tables appear in the front end without swapping between systems? ie when I flick through it doesnt matter if its a VPX or and FX3 file they all appear on the wheel? Thanks in advance
Please attach your pinballx\config\pinballx.ini file.
It sound like in settings.exe under display settings you have 'Use Direct B2S in Front End' set to Yes for the VPX backglass images.
For the list you want to select the All Tables menu option.
If these are the only 2 systems, you can use the all tables option. If you got more systems, and want to combine them, you can create a group and group those 2 databases together
