Please help problem with jpac keypresses i think???
Hi
I wonder if someonecould help out here before i loose all my hair.
my problem is i have a bas machine running gamex and only just noticed today when i played double dragon in 2 player mode, but both 1 and 2 player have the same keypresses, ie when 1 player punches, player 2 does the same as it seems to be on the same keys,although the joystick of p1 and p2 move independantly the buttons do not, i dont know any way to sort this, i have tried to reprogram the jpac as its and old model and i just keep getting timeout errors,somehow the keys are the same??????????
please help
andy
Hi
please help
andy
Might want to post this in the ultimarc forum.
Hi
please help
andy
hey dini, i agree with ling as he's been a big help to me in this area. i'm not too sure about the older model ipac mines the newer usb version, but as dumb as it sounds are the wires in the right slots, and connected to the proper cherry switches? also does the ultimarc keymapping program work with that version? any pics?
Is this only in MAME or have you tried in other games as well?
Emph
There is a program I found on Byoac called KEYHOOK.EXE that will tell you what keystrokes are being entered as you press your buttons. It was intended for use with mapping out the matrix on a hacked keyboard encoder but can also be used to troubleshoot in situations such as yours. I'm guessing you either have your encoder wired wrong or mame is setup using the wrong keys. It could be that you just have a faulty encoder. The software is located at BYOAC on the interfaces page in the Keyboard Port - Hacking a Keyboard section. Its the one written by someone named David. Or if you don't want to search for it just get it here http://www.arcadecontrols.speedhost.com/KEYHOOK.ZIP . I hope this helps.
Jay T
Jay T
hi guys
thanks for your replys:
my buttons are set as follows according to the key test program:
Player 1 Button 1 - A+ left ctrl
Player 1 Button 2 - Q+ LAlt
Player 1 Button 3 - S+ Space
Player 1 Button 4 - W
Player 2 Button 1 - A+ left ctrl
Player 2 Button 2 - Q+ LAlt
Player 2 Button 3 - S+ Space
Player 2 Button 4 - Lshift
seems to be duplicating on each side for some reason or another,do you know how to remedy this problem, my keyboard is connected via ps2 if it makes any difference.
cheers andy
ive checked in mame and my settings are:
Player 1 Button 1 - left ctrl
Player 1 Button 2 - LAlt
Player 1 Button 3 - Space
Player 1 Button 4 - Lshift
Player 2 Button 2 - S
Player 2 Button 3 - Q
Player 2 Button 4 - W
any ideas
thanks andy
hi guys
cheers andy
any ideas
thanks andy
Wow thats pretty strange. It looks to me like some of the wires are either mixed up in your CP or you have a bad JPAC. Also you might try as someone suggested to look over at ultimarc's site to see if anyone else has had this problem. Has this problem just cropped up recently? Is this a new Control panel? Maybe, if it were me, I would unhook player 2's buttons and try the keyhook program again on P1's buttons and see if you still get the duplicating keypresses. So P1 button 1 should be left ctrl when pressed not A+ left ctrl. If the duplicating error gos away then you probably had it wired wrong, if after unhooking player 2's buttons you still get the duplicating error on P1 then I would guess faulty jpac or possibly the jpac programing software has screwed the settings up, though I think this would be unlikely. I hope this helps.
Jay T
