[RESOLVED] Pinball x 4.33 block and freezy exiting vpx.
Luiszx
2 hours ago, scutters said:
Maybe you did select pin2dmd support during pinballx install as i don't think you should have those files in you pinballx directory when running a virtual dmd
Safest way to check is install pinballx in a new directory to test (you can delete later), don't select to install pin2dmd support. Copy your database folder and ini file across to the new install and let us know if the issue is still present.
Scutters you are a GREAT !! You managed to notice a small detail .. it is really true often the big problems are solved with little but only the careful eye can do it .. good !! I kindly ask you 2 other things. 1) When I start PX I want to have the list of emulators and then I enter one or the other, but then I don't find in the settings any key to go back in the list of emulators. Example: I enter mame, play a game, go out and then I can't switch to visual pinball without leaving PX. Is there any way to do it?
2) Kindly give me a link to setup future pinball, pinballFX3 and visual pinball9 in PX.
THANK YOU SO MUCH!!!!!
Link to comment
Share on other sites
No problem, just as well you mentioned those two files :)
1/ In setttings.exe go to General Settings - make sure you have Systems List enabled (that should then show a 'systems' option in the menu which i think is what you want)
2/ Other visual pinball version setup will be similar to what you have now for VP10 (just set it up as a different system under Other systems in settings). For FP and FX setup have a look in the FAQ section https://www.gameex.info/forums/forum/32-faqs-guides-other-useful-information/  (I don't use either)
Link to comment
Thank you for your quick answer. I enabled the list of emulators at the beginning and I have no problems when I enter one emulator or another. The problem is that once I'm in one emulator I can't go out and switch to another emulator. To do this I must necessarily exit pinballx and then enter again and choose another emulator. I am attaching photos ... of all the configurable keys, no one allows me to leave a list of a specific emulator to go to another?
As for visual pinball9 I know that I can configure it as visual pinballx but I don't know where to configure it in the Pinballx system since I already have the mame in "other" systems.
Link to comment
27 minutes ago, Mike_da_Spike said:
You have in others system the option to setup 25 different emulators. All numbered via a pull down select box
Ok i test after.
I solved how to get out of one emulator and get into another.
Link to comment
