Hi
Having got back into the swing of updating my virtual pinball machine , which has joystick and controls with the much needed help of some of your members i thought i could share my pcsx2 setup with you.After a day messing about with i rotate and parameters i came up with the following which works with iso files and doesn't mount the dvd/cd
Please correct if anything could be done easier but i found it works perfect for the few games i require
Firstly i use pcsx2 and i found this plugin http://www.pbernert.com/cdvdpeops102.zip for the cd/dvd only worked for me nothing else would boot (place in pcsx2 plugins)
ok thanks to joyrider3774 i made these ahk and bat filesstart.ahkexit.ahk
all standard installation folders,if you dont have irotate then https://www.entechtaiwan.com/files/irotate.exe
pcsx2 launchbefore.batFetching info... pcsx2 launch after.batFetching info...
which i placed in pinballx/scripts folder(with the ahk files)
Ok this is my first post to help others,please ask me to change anything that is incorrect or not in order Its just a nice have to play a few ps2 games with ease
thanks to all in the community it makes it a joy to build cheers
Thanks for sharing your solution. Would you mind attaching a copy of your pinballx.ini to go along with the image? While file locations may be different, the gist of the setup, command lines, etc. will be preserved. Thanks!
sorry i forgot to mention that it is a two screen setup with the play-field in landscape hence the rotating of the screen, this setup can be used with other emulators that require turning.
cheers
  • Draco1962 changed the title to Pcsx2 - How to set up in PinballX
  • Draco1962 locked this topic
