Not having your support files attached to your makes it s guessing game for usvto help you.
Please attach copies of your pinballx.ini and log.txt files whenever you have a problem to report.
Assuming you may be using Windows 10, please refer to the following links:
https://support.microsoft.com/en-us/help/4558286/windows-10-add-an-app-to-run-automatically-at-startup
And
https://support.microsoft.com/en-us/help/4026268/windows-10-change-startup-apps
Let us know if this resolves the reported issue. Thanks.
  On 5/31/2020 at 7:37 PM, Draco1962 said:
Non avere i tuoi file di supporto allegati al tuo fa indovinare il gioco per noi per aiutarti.
Allegare copie dei file pinballx.ini e log.txt ogni volta che si verifica un problema.
Supponendo che tu stia utilizzando Windows 10, fai riferimento ai seguenti link:
E
Facci sapere se questo risolve il problema segnalato. Grazie.
I use windows 7
there is a file in the install directory of Pinballx called Togglestartwithwindows.exe
If you launch it once (you dont see anything happening), pbx will start next time after windows startup. Launching it again , it will not start during windows launcb
So just click it once and test it (nothing is showed during the launch of this program)
The option in settings, never worked for ne
