Hi, i have a pinball with 3 screens , THE playfield is a 42 inch backglass 23 inch and THE screen for dmd 19 inch
now THE problem ,playfield is playing good no issues backglass Some tables good and Some tables to small
the dmd is way to big full screen and a little bit in THE playfield
how can i get this working good  , i have try THE y and x  but dont no what that do or means
When reporting an issue or requesting assistance, please attach copies of your pinballx.ini and log.txt files. Thanks.
It's the \pinballx\log\log.txt and \pinballx\config\pinballx.ini files that should be attached.
If you want to change the size of the DMD and backglass areas it's the width and height you should change, and then position that area using the x and y
hi guys i have try THE to get THE log but dont no how but i have THE vpx working with 3 screen dmd but THE vpt
tables is THE dmd to big its over almost 2 screens , how do i get this dmd work good
Sorry, i'm not sure what you mean. Is the DMD area too big while playing a game (vpx and vpt?), or is it the wrong size in pinballx?
Hi , THE problem was that iTS to big in pinballx ,but not in ddraw , i sloved it i think ,
with setdmd i pickt iT up THE dmd test screen and put iT in THE right screen with THE good resolution
and save iT to all my roms ,and in pinballx i have THE same resolution ,when i select a game
IT goes  first to THE wrong screen and i most Press F1 and i select anthor dmd Dll demension
And  now iT stays in place even when i turn THE pc off ,i most do this with all my tables (selecting Dll dmd)
so THE problem is sloved ,now all my software is good and running finnaly B)
