Within settings.exe you can do a launch after like
Quote
C:\Windows\System32\Taskkill /IM "PinSoundStudio.exe"
I call this command in a batch file as a 'launch after';
TASKKILL /F /IM "PinSoundStudio.exe" /T
Some people leave it running minimised. I prefer to close it after each table.
9 minuti fa, gli scouter dissero:
Chiamo questo comando in un file batch come 'launch after';
TASKKILL / F / IM "PinSoundStudio.exe" / T
Alcune persone lo lasciano funzionare minimizzato. Preferisco chiuderlo dopo ogni tavolo.
what should I enter in launch after working path?
Just change it to whatever folder you keep the batch file in
you in launch after working path: c: \ custom script do you have a script file what should i insert?
The KillPinSound.bat batch file just contains the TASKKILL line in my post above. You can paste that line into notepad and then save as a .bat file by changing the 'Save as type' drop down to All files in Notepad.
I have that file saved in C:\customscripts and so set that as the working path, but you can save it wherever you want and change the working path to match.
  • Thanks 1
