how can i solve the problem on some tables the dmd is hiding under the backglass, how can i bring the dmd to the foreground above the backglass? thanks
When reporting a problem or requesting assistance, please attach copies of your pinballx.ini and log.txt files for review. Thanks!
Also, knowing what pinsim(s) are impacted is helpful as the solution is not always the same for each.
This files
PinballX.ini log.txt
Do you have your backglass set : bting to front ? This wil also set the backglass over the DMD (sorry, im using a real dmd, so not displayed on my backglass)
1883520567_SmartSelect_20200513-162437_SamsungInternetBeta.thumb.jpg.400eeb46d466c77f0babc18752b13215.jpg
no work
 work!!! thank you
