[RESOLVED] load pinball arcade free camera mod from PinballX
hi i really need help on this one i been going nuts for almost a week the closest i got is load a table but its stay on for 5 to 10 second and go back to PinballX
could anyone who have one working show me his setup by the way i have all the table running the original steam version but i see only 66 tables
6 hours ago, Mike_da_Spike said:
Please provide your log file where the issue occurs.  Also post your pinballx.ini.
Both as attachment please
here u go hope it help
PinballX.ini log.txt
What exe did you set in TPAFreecammod for pinballArcade itself ?
Is that PinballArcade11.exe?
If so, try to run PinballX as admin
  • Thanks 1
thx a lot  that did the trick the game work but i still see only 69 tables any idea how to fix that ?
forget my last question found out how sometime i wonder how stupid i can get lol
Not sure what fixes your issue (for future reference to help others with the same issue)
20 minutes ago, Draco1962 said:
My guess would be he had an old xml with only 69 tables.
i have a old xml would love the new one with all the table now im putting them on 1 by 1 manually
for the game to start u were right have to launch pinball x in admin right
  • Thanks 1
Probably best that way due to some xml files are custom to someone else's system. I generally do my own. Using Notepad++ instead of Notepad also a big help.
im just using the game manager from pinball X and its working
You can also try this instead of game manager:
