I had this issue years ago and can't recall what the fix was. But when I launch PBX, it starts act like it will load but then closes. I thought this meant an issue with the xml file like a syntax issue but I copied the whole contents to a an online validator and it found no issues. It was just working fine yesterday or day before. I have been adding a bunch of tables since the last time it worked so I suspect a typo somewhere but not seeing it. here are my specs and files attached:
windows 7 64 bit
Latest version of PBX just released this past week and latest vpx and vpinmame versions. (works fine launched outside PBX)
using notepad ++ for editing the xml
3 screen setup with digital plunger (ZEBs)
PinballX.ini log.txt VP 10 Tables.xml
Log file shows an error;
Could not find a part of the path 'C:\Pinball\PinballX\Media\Ambiance'.
Have you inadvertently dragged that folder somewhere else?
Oh shoot, come to think of it, I did delete some folders thinking I didn't need them. So I created a new Ambiance folder in the media folder and now it opens. curious, what is that folder for? there is nothing in it. Guessing somewhere in setup there must be a path specified for this. Thanks!
So all working ok now?
