I love the program and think if i can ever get past the mapping my buttons it would be fantastic. I am a first time builder and operating windows 10 professional. I just cant get a program to load and mapped properly. I have a total of 10 buttons and 1 ball launcher from VirtuaPin. I am sure it is something simple that this rookie is missing. Please help set me on the Virtual Pin Ball playing path..
[Display]
Monitor=0
rotate=90
Windowed=False
windowwidth=812
windowheight=457
windowx=543
windowy=752
PlayFieldBrightness=230
WheelTextColor=ffffffff
InfoTextColor=ffffffff
InfoTextOutlineColor=ff000000
FilterTextColor=ffffffff
MenuColor=ffffa500
[BackGlass]
monitor=1
x=0
y=0
width=1920
height=1080
AutoPositionB2S=True
UseB2S=True
[DMD]
Enabled=False
monitor=2
x=0
y=0
width=900
height=300
AutoPositionPinMAME=False
[FileSystem]
EnableFileMatching=True
[Interface]
UseTableLoadingMedia=True
GIFbackgroundcolor=ff000000
DesktopModeEnabled=False
EnableAdditionalDetail=True
ShowSystem=True
ShowRatings=True
WheelOverlay=3
OneClickLaunch=True
EnableBasicMenuMode=False
[Audio]
StreamVolume=90
SampleVolume=90
PlaySoundInVideos=True
[Startup]
playsound=True
playvideo=True
StartWithWindows=No
[KeyCodes]
quit=27
left=37
right=39
select=13
rotate=82
pageleft=33
pageright=34
exitemulator=81
ingame=80
screenshot=83
capturevideos=86
instructions=73
volumedown=109
volumeup=107
credit=53
plunger=164
launch=50
[JoyCodes]
quit=7
left=9
right=1
select=8
rotate=
pageleft=10
pageright=2
exitemulator=
ingame=6
instructions=
launch=
Credit=11
Plunger=15
[Text]
All=All
PlayGameTwoPlayer=Two Player Game
Line1=Free Play
Line2=Press Start
Featuring=Featuring
Tables=Tables
PlayGame=Play Game
Instructions=Instructions
Information=Information
Flyer=Flyer
Gameplay=Gameplay
Tutorial=Tutorial
Promo=Promo
ExitGame=Exit Game
ReturnToGame=Return to Game
Return=Return
Exit=Exit
Shutdown=Shutdown
Favorite=Favorite
Favorites=Favorites
FavoritesAdd=Add To Favorites
FavoritesRemove=Remove From Favorites
MostPlayed=Most Played
LastPlayed=Last Played
Lists=Lists
CapturingVideos=Capturing videos. Please wait. This will take several minutes.
Ratings=Ratings
HighScores=High Scores
RateTable=Rate Table
NotRated=Not Rated
Systems=Systems
RecentlyAdded=Recently Added
[FuturePinball]
WorkingPath=C:\Games\Future Pinball
TablePath=C:\Games\Future Pinball\Tables
Executable=Future Pinball.exe
LaunchBeforeEnabled=False
LaunchBeforeWorkingPath=
LaunchBeforeExecutable=
LaunchBeforeHideWindow=False
LaunchBeforeWaitForExit=False
LaunchAfterEnabled=False
LaunchAfterWorkingPath=
LaunchAfterHideWindow=False
LaunchAfterWaitForExit=True
MouseClickFocus=True
FPRAMPath=C:\Games\Future Pinball\fpRAM
[VisualPinball]
WorkingPath=C:\Visual Pinball
Executable=VPinballX.exe
LaunchBeforeEnabled=false
LaunchBeforeWaitForExit=True
AutoConfigure=False
[ExitScreen]
EnableExit=True
EnableShutdown=True
[StartupProgram]
Paramaters=
HideWindow=true
WaitForExit=false
[ExitProgram]
Enabled=false
WorkingPath=
Paramaters=
HideWindow=False
WaitForExit=
[AttractMode]
Timer=1
ShowFor=15
MuteAudio=False
[System_1]
Name=MAME
Enabled=False
TablePath=C:\
Executable=mamep64.exe
Parameters=[TABLEFILE]
SystemType=0
[AutoExit]
Minutes=30
[Login]
StreamQuality=10
[PinballFX2]
Executable=steam.exe
Parameters=-applaunch 226980 [TABLEFILE]
Process=Pinball FX2.exe
Rotate=False
WaitFor=20
[PinballArcade]
Parameters=-applaunch 238260
Process=PinballArcade.exe
WaitForSelect=50
[GameListManager]
onlinemode=false
[RealDMD]
EnableColor=True
Color=ffff1414
[PinballFX3]
Parameters=-applaunch 442120 "-table_[TABLEFILE]"
Process=Pinball FX3.exe
Rotate=False
WaitFor=20
[Topper]
monitor=2
[VideoCapture]
KeysStartRecord=164|120
KeysEndRecord=164|120
Seconds=45
UseGPU=False
[Internal]
lastwheelcachematchsize=625300
lastselected=ExcaliburExcaliburPinball FX2
filter_year=
filter_company=
filter_custom=
filter_favorites=False
filter_lastplayed=False
filter_mostplayed=False
filtername=All Tables
filter_rating=0
filter_system=
filter_recentlyadded=False
lastwheelcachematchsize2=307676
[Plugin_1]
Enabled=False
Name=PlugInLED.dll
[Plugin_2]
Enabled=False
Name=PlugInSpeech.dll
[Plugin_3]
Enabled=False
[Plugin_4]
Enabled=False
Name=Xpadder Plugin.dll
[Apron]
monitor=8
[SetupWizard]
EmuPath1=C:\Emulation\Emulators
AssetPath1=C:\Emulation\Assets
ROMPath1=C:\Emulation\ROMs
DefaultPathPrompt=True
DownloadDatabasePrompt=True
DownloadEmulatorPrompt=True
WizardMode=Advanced
SavePosition=False
SearchText=
EmulatorIndex=0
EmulatorGroupIndex=0
DaphneIndex=0
HTMLAppsIndex=0
ExternalAppsIndex=0
RadioStationsIndex=0
NewsFeedsIndex=0
MappedDrivesIndex=0
SystemIndex=0
ShowPanel=True
FontSize=1
WindowSize=650, 478
WindowLocation=17, 275
WindowState=Normal
CustomArray=
SearchArray=
SectionIndex=23
[GameManager]
AutoAddTablesFrontEnd=True
Not sure whst your question and issue is.
Will this  helps?
http://www.gameex.info/wiki/index.php/PinballX:Visual_Pinball_Settings_(Setup_Wizard)
Edit  If you want emulators like Visual pinball , fx3, future pinball too work, make sure it just works on your pc and that you can launch a single table from the command prompt. If you get this to work, it is easy to implement within pinballx
As you mention virtuapin also have a look at
(ignore the config for tilt etc if you have that working - just look at the pinballx and visual pinball button settings, yours should be similar - assuming you wired the virtua pin controller buttons as their documentation)
